2jay
Message 11 of 16
Re: Broadband slowing down again how do I proceed please?
That's a very good check list Thanks. But nothing has changed within the house as far as I can tell , what could it be that interfered for days and days and then stopped at lunchtime? The quiet line test didn't reveal any noise at all. Thanks for the input.
Sammorley
Message 12 of 16
hi, ive had the EXACT !! Same problem, from around the same date !! all is fine when reset for a few days, then conn speed starts droping again !!
2jay
Message 13 of 16
Hey guess what? It's gone again & so has the upstream?
BT test says
Download speed achieved during the test was - 1600 Kbps
 For your connection, the acceptable range of speeds is 600-7150 Kbps.
 Additional Information:
 Your DSL Connection Rate :2912 Kbps(DOWN-STREAM), 64 Kbps(UP-STREAM)
 IP Profile for your line is - 2500 Kbps
Ohh help..................:(
Message 14 of 16
sorry to ask again but it can make a difference so do you have any other sockets apart from the master to which you are connected
2jay
Message 15 of 16
Hi There is another phone socket, i connect via ethernet cable to the router plugged into the master filtered socket. It was rewired by a BT engineer a couple of years ago after some building work. And the house wiring checked out AOK at beginning of July when BT Openreach engineer came. Thanks,
Message 16 of 16
if you are using a filtered faceplate then that will eliminate any noise from your other extension
