Message 1 of 35
Broadband speed and connection issues - looking for help
Hi,
I hope someone can assist. Within the last 2 weeks my broadband has gone from hero to zero and despite contacting the on-line chat help I dont appear to be getting anywhere.
I have followed the instructions on the info needed.
The quiet line test was fine.
Many thanks for any help offered,
Nick
34 REPLIES 34
Message 2 of 35
Re: Broadband speed and connection issues - looking for help
Which BT home hub do you have?
Message 3 of 35
Hi Keith, a Home hub 3
Message 4 of 35
can you post your stats
From http://192.168.1.254
Settings >
Advanced Settings >
Broadband >
Connection >
Click "Show Details" Button at the bottom
You can also try the direct link
http://192.168.1.254/index.cgi?active_page=9116
Message 5 of 35
speed tests must be done with a wired connection not wireless
Message 6 of 35
Here are the details.
I will also re-run the speed tests as I am now using an ethernet connection
Message 7 of 35
connection time is only 3+ hrs was that manual reset or router dropping connection?  your noise margin is high as normal about 6db have you been having problems with dropped connections
Message 8 of 35
are you using the test socket or somewhere else?  if not test socket can you move to test socket with new filter as with your attenuation I would expect a connection speed about 20mb not the 1+mb you have just now
Message 9 of 35
updated reports
Message 10 of 35
It was a power outage this time, but yes we have been experiencing dropped connections for the last week or so. They have been happening every 30 minutes or so
