SimonPW1
Message 1 of 7
Broadband speed, are these reasonable?
Hi, this is a basic question but can someone kindly tell me if the speeds below are "reasonable" for my BT Infinity hub...I've run the proper BT Speed Test a few times and got these averages....Download=35, Upload=3, Ping=44.  Thank you!
6 REPLIES 6
john46
Message 2 of 7
Re: Broadband speed, are these reasonable?
Can you run this checker and post back a screen shot of the results. Make sure you delete your phone number before posting.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
Can you use this speed tester then carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down. This test must be done with a wired connection.
http://speedtest.btwholesale.com/
if you have a Homehub 5 can you also post the stats from 1-12 by logging onto the homehub management pages then troubleshooting > helpdesk. http://bthomehub.home/
imjolly
Message 3 of 7
there is no way to tell if they are good, bad or indifferent until you post the information requested by john46 which will give something to compare against
SimonPW1
Message 4 of 7
Thanks for replies, my question was just for my understanding really, all I anted to know was whether the following results would these be regarded as "Reasonable" averages for Infinity...Download 35, Upload 4, Ping 44. .....the reason I was askig is that upload speed of 4 looked very different from the others and just wanted to understand if this was a typical number?  Thank you!!!
imjolly
Message 5 of 7
without knowing what your stats show and what your estimated speed are you cannot say whether speeds are good or bad
if you are on infinity 2 for example then they are terrible
SimonPW1
Message 6 of 7
ah got it!  Ok, this is what I got using the link you kindly sent me ...
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
  HighLowHighLow
FTTC Range A (Clean)8079.82020--Available
FTTC Range B (Impacted)8059.12017--Available
WBC ADSL 2+Up to 12--10.5 to 14Available
WBC ADSL 2+ Annex MUp to 12Up to 1.510.5 to 14Available
ADSL MaxUp to 8--7 to 8Available
WBC Fixed Rate2 ----Available
Other Offerings
Fibre Multicast------Available
Copper Multicast------Available
john46
Message 7 of 7
now we need the speedtest Further diagnostic part and the help deskpage from the hub interface
