Message 1 of 19
Broadband speed dropped 3 Months ago and wont go back to previous speed
Hi All,  hoping someone can help.  3 Months ago I was getting 1.7-1.8mb BT Vision worked, I could stream movies and watch iplayer.  My exchange (but not my cabinet) was upgraded so although half the village have infinity I don't and what's more is  my speed which dropped to 700kbps although having increased is now only back to 1.2mb.
I have had numerous calls with advisors who say they have re-set profiles, sent a HH3, suggested new filters etc etc but still nothing has improved and I am still not back at previous speeds. The hub is plugged directly into the test socket section of the master.
HH Manager currently shows
Line state:Connected
Connection time:1 days, 00:36:57
Downstream:1.406 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Interleaved
Noise margin (Down/Up):8.0 dB / 17.0 dB
Line attenuation (Down/Up):61.9 dB / 30.0 dB
Output power (Down/Up):17.2 dBm / 12.4 dBm
FEC Events (Down/Up):13212 / 724
CRC Events (Down/Up):12 / 327
BTW speed test results show
 Download speedachieved during the test was - 1.23 Mbps
 For your connection, the acceptable range of speeds is 0.4 Mbps-2 Mbps.
 Additional Information:
 Your DSL Connection Rate :1.44 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 1.25 Mbps
The IP profile dropped since put in a new filter in yesterday
Below is a graph from the SamKnows dashboard
Can anyone interpret this dats and make any suggestions on my next steps with this problem
18 REPLIES 18
Message 2 of 19
Re: Broadband speed dropped 3 Months ago and wont go back to previous speed
you have a higher than normal noise margin once you can post 3 days stable connection the forum mods can then arrange a noise margin reset which will improve your speed
Message 3 of 19
were your stats and btspeedtester results done at same time just the conenction speed from router is not same as btspeedtester figure.
your profile is controlled by your conenction speed not other way round - so to get a higher profile you need a faster conenction speed
Message 4 of 19
thanks both
Yes they were both at roughlly the sametime and yes I will wait until I have a stable connection for three days (dont hold your breath)
Message 5 of 19
Today Hub manager says
Connection time:0 days, 08:07:25
Downstream:1.594 Mbps
Upstream:448 Kbps
and BTW test says
 Download speedachieved during the test was - 1.2 Mbps
 Your DSL Connection Rate :1.63 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
I dont understand and I don't seem to be able to get this accross to anyone I speak to.
Message 6 of 19
Have you tried the quiet line test to see if any line noise?
Guru
Guru
Message 7 of 19
Hi gazamataz,
What's causing the DSL connection to drop? as you only have an ~8 hour uptime connection?
Constant dsl connection drops/resyncs can cause the sync rate to decrease, noise margin to increase or IP profile to decrease
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Message 8 of 19
Still unable to get a stable connection of more than a few hours at a time.  looking at HH stats there must have been another dosconnection recently as now shows
Line state:         Connected
Connection time:            0 days, 00:37:12
Downstream:     1.438 Mbps
Upstream:         448 Kbps
Can the Mods please help here ?
Message 9 of 19
Can you post the full adsl stats including errors not just the abbreviated version
did you try quiet line test to check for line noiseas that could well be cause of dropping connection?  Are you still in test socket?
Message 10 of 19
ADSL Line Status
Connection Information
Connection time:0 days, 01:00:16
Downstream:1.438 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):8.2 dB / 17.0 dB
Output power (Down/Up):17.3 dBm / 12.3 dBm
FEC Events (Down/Up):1273 / 1
CRC Events (Down/Up):0 / 0
No noise on quiet line test and still in test socket
