grant01
Message 1 of 9
Broadband speed dropping heavily the past week....
speeds have been horrible...when 2 people using wifi its literally impossible to use. cant even google something its that bad!
ADSL Line Status
Connection information
Line state:Connected
Connection time:2 days, 23:18:23
Downstream:2,080 Kbps
Upstream:448 Kbps
  ADSL settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Fast
Noise margin (Down/Up):8.8 dB / 12.0 dB
Line attenuation (Down/Up):58.0 dB / 31.5 dB
Output power (Down/Up):17.2 dBm / 12.9 dBm
FEC Events (Down/Up):0 / 8
CRC Events (Down/Up):2502 / 14
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
Loss of Link (Remote):0
HEC Errors (Down/Up):1135 / 10
Error Seconds (Local/Remote):0 / 0
 More Details
 Hide Details
8 REPLIES 8
imjolly
Message 2 of 9
Re: Broadband speed dropping heavily the past week....
Then run  btspeedtester  (MAC users may have problems). when first test completes then run diagnostic test and post the results ( do not reset the router).  must be done with wired connection
can you enter your phone number and post results  remember to delete number  https://www.btwholesale.com/includes/adsl/main.html
are you connected directly via a filter to the NTE5 master or test socket or to somewhere else? Is the master the only phone socket in your home?
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
Someone may then be able to offer help/assistance/suggestions to your problem
grant01
Message 3 of 9
FAQ
Results Image not loaded
1. Best Effort Test:  -provides background information.
 Download  Speed
 0.84 Mbps
0 Mbps2 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 0.84 Mbps
 For your connection, the acceptable range of speeds is 0.8 Mbps-2 Mbps.
 IP Profile for your line is - 1.83 Mbps
2. Upstream Test:  -provides background information.
 Upload Speed
 0.34 Mbps
0 Mbps0.45 Mbps
Upload speed achieved during the test was - 0.34Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.45 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Please visit the FAQ if you are unable to understand the test results.
john46
Message 4 of 9
Was the speedtest done using a wired connection
grant01
Message 5 of 9
yep!  and my router has restarted itself sinec i posted that so i had to wait another 3 days...and then it done it again.. speeds are worse now.
i used to get around 3,700kbps  now im on 2,300kbps and two people cant use the net at the same time its that **bleep**
imjolly
Message 6 of 9
Are you using test socket with new filter?
did you try quiet line test?
grant01
Message 7 of 9
yep done all that
grant01
Message 8 of 9
is my line noisy? are all the crc and HEC errors a problem?
ADSL Line Status
Connection time:0 day, 21:36:57
Downstream:2,368 Kbps
Upstream:448 Kbps
  ADSL settings
VPI/VCI:0/38
Type:PPPoA
Latency type:Fast
Noise margin (Down/Up):6.1 dB / 14.0 dB
Output power (Down/Up):17.3 dBm / 12.9 dBm
FEC Events (Down/Up):0 / 3
CRC Events (Down/Up):39735 / 40
HEC Errors (Down/Up):13862 / 20
 More Details
 Hide Details
iss
imjolly
Message 9 of 9
as your latency is 'fast' the errors are not that high
are you crrently connected to test socket with filter and without need for phone extension cable?  if in test socket are your extension sockets 'dead'
