Message 1 of 11
Broadband speed dropping to almost nothing until hub reset
Hi,
I've fibre broadband Infinity 1 and for about the last 3 months have noticed that the speed is dropping to almost nothing as the night goes on, although hub stays on. normally I get about 28 Mbps but at night I'm down to less than 1Mbps - switch hub off/on resets it back to 28Mbps.
this is a new hub i received last week (to resolve this problem) after phoning BT - they checked speedtest and said speed from exchange to house was fine (22 Mbps) - but speed from old hub to devices was the blamed culprit.
my connections to hub are wireless (tv, 2 phones and an ipad). hub is about 4 metres from anything and signal goes through one wall.
Any advice?  or do i just reset the hub once a day?
Frank
10 REPLIES 10
Message 2 of 11
Re: Broadband speed dropping to almost nothing until hub reset
please don't reset the hub on daily basis as that will more than likely make matters worse
can you post stats from your hub  if hh6 then go to advanced settings then technical log information
try quiet line test  dial 17070 option 2  should be quiet and best with corded phone
can you run btspeedtester and when first test completes then run diagnostic test and post results  then run test again tonight when speed is low for comparison
Message 3 of 11
Here's the reading when my broadband is running at correct speed:-
Product name:
BT Hub 6A
Serial number:
+084319+NQ73978605
Firmware version:
SG4B1000B522
Firmware updated:
31-Jan-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 0 Hours 48 Minutes 9 Seconds
Data rate:
7.77 Mbps / 30.43 Mbps
Maximum data rate:
7856 / 36849
Noise margin:
6.2 dB / 6.3 dB
Line attenuation:
26.8 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
4144 MB Uploaded / 4772 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-8CZP
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
BTHub6-8CZP
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
58:90:43:F6:B6:2C
Software variant:
Boot loader:
9.2.0
Message 4 of 11
Here's it 3 days later when I was getting 1.5 Mbps from the hub:-
Product name:
BT Hub 6A
Serial number:
+084319+NQ73978605
Firmware version:
SG4B1000B522
Firmware updated:
31-Jan-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
3 Days, 0 Hours 36 Minutes 48 Seconds
Data rate:
Maximum data rate:
7842 / 35672
Noise margin:
6.2 dB / 5.7 dB
Line attenuation:
26.8 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
6336 MB Uploaded / 16611 MB Downloaded
Broadband username:
BT Wi-fi:
Active
BTHub6-8CZP
Smart (Channel 1)
BTHub6-8CZP
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
58:90:43:F6:B6:2C
Software variant:
Boot loader:
9.2.0
Message 5 of 11
I can't test the line as I don't have a landline phone - I only use mobile.
Also - I'm not having a problem with Exchange to house, it's hub to devices that deteriorates as time goes by.
How do you suggest I watch something like Netflix if i can't reboot the hub (which gets the speed back up)?
Message 6 of 11
Can you at least post the speed test reults asked for.
It is also advisable to have a corded phone connected as it provides a "wetting" current on the line which helps prevent corrosion building up on joints. One can be picked up for about £5 from a well known catalog store.
Message 7 of 11
@Darkfung  Constantly resetting the router will trigger the DLM into thinking line is unstable resulting in noise margin increasing and speed decreasing. If the resets continue then you will probably end up in a banded profile which at present can take weeks to get out of
but up to you
Message 8 of 11
if you sue an ethernet conenction does your download speed appear to drop like your wirless conenctions
remember Btspeedtester must be done with wired conenction not wireless
Message 9 of 11
Hi
btspeedtester is telling me it can't fetch the results and only confirming speed from exchange to house. I've run it each night for the past several days and each time i get the "can't fetch" message. (running it on laptop wired to hub)
I'll buy a cheap corded phone see if that helps.
I'm stuck for connecting via cable as my hub is downstairs and the slow speed is being reported by netflix on my tv upstairs - but I'll try netflix on a wired laptop tonight next to hub.
just for clarity - no problems at all until about 3 months ago.
... and thanks for all the help thus far 🙂
Message 10 of 11
I have - they're 2 message up.
