Message 21 of 47
Re: Broadband speed extremely slow after the first 10 days
Yes I've been connected to the test socket for like a week now, The phone has only rang once since it was setup and that was yesterday afternoon, I had a 2 day 6 hour connection this morning so no it doesn't. Nobody really has the landline number yet.
Message 22 of 47
ok just trying to eliminate possible problems
Which home hub are you using ?
Message 23 of 47
Homehub 3 I believe
Message 24 of 47
Message 25 of 47
did you check the link I posted for possible sources of interference?
Message 26 of 47
Yeah it's a homehub 3, I did check the other day and state that in one of my previous posts.
There is nothing near the homehub that could be interfering with it I don't think, I did check your link but my phone socket is right by the front door in the hall, and that's where the homehub is and has been since I set it up 2 weeks ago, and I don't think anything like that is close enough to interfere.
The first day I did have a range of speeds from 2-12mb until it dropped to what it's currently at.
This is just annoying because my last house was a lot further away from the exchange and I had 6 Mb down consistently from day 1, and that had dodgy wiring, the electric used to go off at least once a day, I was never put into a banded profile from the router resetting there.
I'm a lot closer to the exchange now, our estimated speed range was 7-14 Mb and our neighbours are consistently getting 12 Mb
Message 27 of 47
you could have been on ADSLMAX up to 8mb service at your old home which does not have banded profiles as does ADSL2+
Message 28 of 47
can you post up to date stats from your router please.  do you use an phone extension cable to conenct hub to test socket?
Message 29 of 47
No extension no, plugged into filter, filter plugged directly into test socket, it's definitly the master socket as it's the only phone socket in the house, and the cable comes in from the telegraph pole just underneath it.
It's only 2 and a half hours because of all the disconnects this afternoon. I was at 2 days 10 hours this morning with no error seconds or HEC Events, just 724 FEC events down/0 up
Message 30 of 47
Due to all the drops/resets in connection your connection is now in a banded profile which should release automatically given 24/7 connection for 3/5 days. If you get to 3+ days connection time and connection speed still the same then repost stats and mods may help get you out of banding.
Hopefully engineer has fixed problem and connection is now ok
