Langy91
Message 21 of 24
Re: Broadband speed has dramatically reduced, i'd be faster on Dial up.
Ok well I removed it and everything is still the same, anything else?
Message 22 of 24
if you have removed fron both sockets then can you post stats again please
Langy91
Message 23 of 24
 Download speedachieved during the test was - 434 Kbps
 For your connection, the acceptable range of speeds is 200-1000 Kbps.
 Additional Information:
 Your DSL Connection Rate :5568 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
 IP Profile for your line is - 750 Kbps
Message 24 of 24
the change has more than doubled your connection speed to 5568 but the previous low connections have reduced your profile to 750 which is restricting your download speed.  you now need to leave things connected 24/7 for the next 3/5 days maybe sooner and your profile will return to normal with corresponding increase in download speed
