Nickeepowell
Message 1 of 6
Broadband speed is slow
Hi all, we've recently switched to BT from plusnet and the broadband speeds seem to be quite a bit slower than they were previously.
The speedchecker says I'm getting 3.3 Mbp/s download speed and I was wondering if there is any way to speed it up?
Here's the results from the availability checker
BT BROADBAND AVAILABILITY CHECKER
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
  HighLowHighLow
Featured Products
WBC FTTP Availability Date
Left in Jumper
ADSL Products
Availability Date
Left in Jumper
Other Offerings
Availability Date
VDSL Range A (Clean)8073.52020--Available----
VDSL Range B (Impacted)8057.12017.1--Available----
FTTP on Demand33030--Available----
WBC ADSL 2+Up to 6--4 to 8Available----
WBC ADSL 2+ Annex MUp to 6Up to 14 to 8Available----
ADSL MaxUp to 5--3.5 to 7.5Available----
WBC Fixed Rate2----Available----
VDSL Multicast------Available----
ADSL Multicast------Available----
5 REPLIES 5
imjolly
Message 2 of 6
Re: Broadband speed is slow
you need to post the stats from the hub - troubleshooting/helpdesk
also run btspeedtester diagnostic test and post results
Nickeepowell
Message 3 of 6
Here's the speedtest
Download Speed (Mbps) 3.56
Upload 0.86
Ping Latency 41.63
and the stats:
1. Product name:BT Home Hub
2. Serial number:+068340+NQ52138191
3. Firmware version:Software version 4.7.5.1.83.8.130.1.26.1.1 (Type A) Last updated 17/12/15
4. Board version:BT Hub 4A
5. ADSL uptime:6 days, 11:29:24
6. Bandwidth:1083 / 4056
7. Data sent/received:1.8 GB / 30.2 GB
8. Broadband username:bthomehub@btbroadband.com
9. BT Wi-fi:Yes
10. 2.4 GHz Wireless network/SSID:BTHub4-HPX3
11. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 144 Mb/s))
12. 2.4 GHz Wireless security:WPA and WPA2
13. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
14. 5 GHz Wireless network/SSID:BTHub4-HPX3
15. 5 GHz Wireless connections:Enabled (802.11 a/n (up to 300 Mb/s))
16. 5 GHz Wireless security:WPA2
17. 5 GHz Wireless channel:Automatic (Smart Wireless)
18. Firewall:Default
19. MAC Address:54:64:d9:25:b0:da
20. VPI/VCI:0 / 38
21. Modulation:G.992.3 Annex A
22. Latency type:Interleaved
23. Software variant:-
24. Boot loader:-
imjolly
Message 4 of 6
can you go to hub manager then troubleshooting then helpdesk logs wan and you are looking for 2 line together showing your connection speed of 4056kbps and also your noise margin.  this will be about 6 days ago when your router last reset
Nickeepowell
Message 5 of 6
Hi thanks for the help,
01:09:37, 14 Jun. ( 106.030000) DSL line rate: 1083 Kbps upstream, 4056 Kbps downstream
01:09:38, 14 Jun. ( 106.940000) DSL noise margin: 5.90 dB upstream, 6.00 dB downstream
imjolly
Message 6 of 6
from the stats your noise margin is about normal 6db and with connection speed within the estimates speed shown by checker there does not seem much improvement left
are you using the test socket with a filter to see if that helps your conenction  test socket.jpg
