Message 1 of 24
Broadband speed issues
Hi,
I have been having issues with low speed/connection for some time.  I used to get speeds of upto 4.0 Mbps.  I am now only getting at best 2.8 and home hub seems unable to maintain a connection for more than a few hours at a time.  This is fine for web browsing but not very good for viewing iplayer.
I have a Home Hub 3, connected to master socket, quiet line test ok, stats below:
Any help appreciated.
1. Best Effort Test:  -provides background information.
 Download  Speed
 2.89 Mbps
0 Mbps4 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 2.89 Mbps
 For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.
 IP Profile for your line is - 2.82 Mbps
2. Upstream Test:  -provides background information.
 Upload Speed
 0.81 Mbps
0 Mbps0.83 Mbps
Upload speed achieved during the test was - 0.81Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.83 Mbps
Connection Information
Line state:Connected
Connection time:0 days, 00:23:17
Downstream:3.117 Mbps
Upstream:1.008 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.3 Annex A
Latency type:Fast
Noise margin (Down/Up):12.2 dB / 6.5 dB
Line attenuation (Down/Up):46.4 dB / 27.3 dB
Output power (Down/Up):18.6 dBm / 12.7 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):11 / 32
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):8 / 8
Error Seconds (Local/Remote):16 / 1
23 REPLIES 23
Message 2 of 24
Re: Broadband speed issues
If you maintain a stable connection for 3 days + you can then get the forum mods to reset your noise margin reset and this will increase your connection speed again
Message 3 of 24
Have you tried connecting to the test socket and see if that helps you maintain connection?
Message 4 of 24
I'll try, thanks.
Message 5 of 24
If you can connect to test socket then repost stats and then if it stays connected repost stats again tomorrow so we can see how the errors have increased and whether that is possibly causing a connection problem. As you are on fast a change to interleaved may help stabilise your connection
Message 6 of 24
Stats while connected to the test socket:
Connection time:0 days, 00:09:10
Downstream:2.648 Mbps
Upstream:1.051 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Latency type:Fast
Noise margin (Down/Up):12.5 dB / 5.9 dB
Line attenuation (Down/Up):46.6 dB / 27.3 dB
Output power (Down/Up):17.7 dBm / 12.6 dBm
CRC Events (Down/Up):2 / 0
HEC Events (Down/Up):0 / 0
Error Seconds (Local/Remote):42 / 12
 Download  Speed
 2.35 Mbps
0 Mbps4 Mbps
 Download speedachieved during the test was - 2.35 Mbps
 IP Profile for your line is - 2.39 Mbps
 Upload Speed
 0.85 Mbps
0 Mbps0.83 Mbps
Upload speed achieved during the test was - 0.85Mbps
Message 7 of 24
Now just leave in test socket and see if it will now stay connected and stable. If so repost stats tomorrow to see how the errors have increased. If ok then just stay connected for 3+ days and mods will help by resetting noise margin to 6db which will give an increase in connection speed and therefore faster download speed
Message 8 of 24
Thanks, will retest tomorrow.
Message 9 of 24
There is always someone around to help
Message 10 of 24
Hi,
Have been connected via the test socket since about 2200 last night.  Latest stats below, connection showing only 8 hours so disconnected at some point.
Connection time:0 days, 08:21:47
Downstream:3.211 Mbps
Upstream:1.07 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Latency type:Fast
Noise margin (Down/Up):12.3 dB / 5.0 dB
Line attenuation (Down/Up):46.5 dB / 27.3 dB
Output power (Down/Up):18.9 dBm / 12.5 dBm
CRC Events (Down/Up):51 / 429
HEC Events (Down/Up):66 / 285
Error Seconds (Local/Remote):122 / 260
 Download  Speed
 2.78 Mbps
0 Mbps4 Mbps
 Download speedachieved during the test was - 2.78 Mbps
 IP Profile for your line is - 2.9 Mbps
 Upload Speed
 0.86 Mbps
0 Mbps0.83 Mbps
Upload speed achieved during the test was - 0.86Mbps
