Message 11 of 21
Re: Broadband speed problems
updated stats here,i'm still have really low speed and crackling online.
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 00:23:08
Downstream:2.39 Mbps
Upstream:217.9 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.3 Annex A
Latency type:Interleaved
Noise margin (Down/Up):7.2 dB / 8.9 dB
Line attenuation (Down/Up):53.1 dB / 48.9 dB
Output power (Down/Up):19.1 dBm / 12.1 dBm
FEC Events (Down/Up):3626 / 19
CRC Events (Down/Up):84 / 32
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):183 / 7
Error Seconds (Local/Remote):73 / 449
Message 12 of 21
if you still have noise on your phone line changing provider will have no affect as they all use the same line back to the exchange and in most cases the same exchange equipment the noise needs fixing first then your broadband should improve
Message 13 of 21
you need to call BT faults on 151 and report the noise but do not mention broadband when you call
Message 14 of 21
It's not just the latest problem thats making me wanna change provider,it's the drop out,custumer service and general average speeds,when you lucky enough to get a decent speed.
Message 15 of 21
but all these are symptoms of noise on your line which you need fixed first
Message 16 of 21
once the line noise is fixed then your problems should disappear your connection speed should then improve as well nearer to 4.3 mb the line noise is the cause of low speed and connection drops until you get that fixed broadband will be unreliable
Message 17 of 21
yes this is the latest problem,what about when line is working fine and I get arbitarty drop out.I've already had a engineer out who fitted new filters etc,now it's happening again.now i' have to take time off work again to fit there times.put it this way i'm not experiencing what there advertising on there **bleep** adverts.
Message 18 of 21
the openreach engineers will be the same regardless of which ISP you use - unless cable.  there will still have the same work times so you will still have to fit in when they are avialable
Message 19 of 21
with a noisy line it will never improve odd drop outs can happen to any one regardless of providers there are many reasons for that including local or national maintenance or network faults
Newbie
Message 20 of 21
Hello Mr Daz
  I am having the same problem as you speed seems to drop out very quickly , have been on to bt and they had an engineer come and said it was outside the property , was even told by a bt member of staff to take the pc back to factory settings as they said it was the browser but this only added to the problem with updates on vista and 000.5 to upload the updates  , they aslo said they would monitor the issue and get back in touch to find today that they say the problem had been resolved , i am seriously on the verge of changing isp as this has gone on since the 16/7/12 when we had option 3 installed , like you i just wish they would do something as this pc is used for important work and relying on my nieghbour to pick up e-mails for me as the system has been so unstable it all seems to be wrong ,just hope bt read our messages as enough is enough .
  Hope you get your issues sorted but dont hold your breath
    Ste44
