Message 1 of 8
Broadband speed recent drop IP Profile stuck low at 2 Mbps
I am new to the forum and I am having trouble with a stuck IP Profile?  I noticed that my speed seemed to have dropped off been low for a couple of weeks, i left everything as is in the hope that it would recover, there was no improvement so I ran a Speed Test.  My speed was nearly always at 5 to 6 Mbps, and my IP Profile always used to be 7 Mbps.
I have been in contact via online chat and was informed there was a faut and it would be sorted within 24 hrs!
there was no improvement so i got in touch again, answered all the questions again this time informed
"I have checked the line for you and I found that there is a fault in the network... I am escalating this case to the Engineers Team (Network Faults Team)" so bassically BT did nothing!
i ran the online test again today with the following results
Download speedachieved during the test was - 1.82 Mbps
 For your connection, the acceptable range of speeds is 0.4 Mbps-2 Mbps.
 Additional Information:
 Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 2 Mbps
7 REPLIES 7
Message 2 of 8
Re: Broadband speed recent drop IP Profile stuck low at 2 Mbps
Hi Welcome to the forums
It looks like you may have a stuck IP Profile if you can post your hub stats so we can see your connection details  this will help us
once you can show 3+days stable connectionwe can put you intouch with the forum moderators who are UK based BT specialists who can arrange a manual reset of your IP Profile
Here is a basic guide to getting help from the community members done by CL Keith Please read through the link posted http://forumhelp.dyndns.info/speed/first_steps.html
once you have posted the information asked for then the community members can help you more
Thank You
This is a customer to customer self help forum the only BT presence here are the forum moderators
Message 3 of 8
i have a TPlink w8960n router not a BT hub connected.
BT Speedtest Results
Router ADSL Information
Statistics -- xDSL
Mode:ADSL_G.dmt
Traffic Type:ATM
Status:Up
Link Power State:L0
 DownstreamUpstream
Line Coding(Trellis):OnOn
SNR Margin (0.1 dB):79210
Attenuation (0.1 dB):15065
Output Power (0.1 dBm):158124
Attainable Rate (Kbps):86401008
 Path 0 Path 1
 DownstreamUpstreamDownstreamUpstream
Rate (Kbps):812844800
K (number of bytes in DMT frame):2551500
R (number of check bytes in RS code word):0000
S (RS code word size in DMT frame):0.501.000.00.0
D (interleaver depth):1100
Delay (msec):0.130.250.00.0
INP (DMT symbol):0.000.000.00.0
Super Frames:6423919642370100
Super Frame Errors:0000
RS Words:0000
RS Correctable Errors:0000
RS Uncorrectable Errors:0000
HEC Errors:0000
OCD Errors:0000
LCD Errors:0000
Total Cells:2093471011000
Data Cells:36689631000
Bit Errors:0000
Total ES:140
Total SES:100
Total UAS:5454
Message 4 of 8
ok please post back in 3 days and if your IP Profile has not risen then we can give you the link to the mods
Message 5 of 8
OK will do
what do you make of the ADSL router details they don't look too bad to me but i am no expert in this field i'm better with avionics!
Message 6 of 8
the stats look ok
Message 7 of 8
Engineers have been in touch and said there was aproblem at the exchange.
All now is working well, broadband speed is back up at 6-7 Mbs and ip profile has changed for the better.
thanks for the help
Message 8 of 8
Glad all is now ok for you 😉
