Message 1 of 16
Broadband speed reduced dramatically
Hi guys first time poster long term lurker,
I'm hopping you can help me here , I have been having connecting problems for the past week. My broadband speed has gone from on average around 6mbps to on average 0.4mbps. Since last week my download speed has constantly stayed around this speed and I'm starting to get a little frustrated. I have contacted bt via live help and they stated I have a ? Fault on my line however the department I was transferred too told me the issue was at my end. I have done the usually tests using the test socket and wired connection however the problem remains.
http://www.speedtest.net/my-result/i/847737593
Line state: Connected
Connection time: 0 days, 05:26:37
Downstream: 7.938 Mbps
Upstream: 448 Kbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.1 Annex A
Latency type: Interleaved
Noise margin (Down/Up): 13.9 dB / 25.0 dB
Line attenuation (Down/Up): 19.1 dB / 10.5 dB
Output power (Down/Up): 19.9 dBm / 12.4 dBm
FEC Events (Down/Up): 195 / 0
CRC Events (Down/Up): 0 / 0
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 0 / 0
Loss of Power (Local/Remote): 0 / 0
HEC Events (Down/Up): 0 / 0
Error Seconds (Local/Remote): 22 / 13
Any help would be greatly appreciated
15 REPLIES 15
Message 2 of 16
Re: Broadband speed reduced dramatically
Sorry I've posted twice , please delete
Thank you
Message 3 of 16
Welcome to forum
are you currently in test socket?  Connection time only 5hrs is that due to router dropping connection or manual reset?
can you run btspeedtester and when first test completes then run diagnostic test and post results.
btspeedtester
it appears that your profile is low and that is reason for low download speed but btspeedtester will show profile
i removed duplicate post
Message 4 of 16
download speed is 0.13mbps
upload is 0.10 mbps
and ping is 187.25
seems to be getting worse. im not currently in the test socket however i was yesterday at bts request and results were no different.
router been connected 5 hours i reset it last night, so im guessing it has possibly disconnected at some point during the day.
Message 5 of 16
That's not results from diagnostic test but from the first test. You need to run diagnostic test which follows after the first test. Only that test shows your profile
Message 6 of 16
Hi when i try to change my user name to complete the tests i get this
The Broadband username that you’ve entered is either incorrect or is not
supported by your BT Home Hub. Please check your username and try again.
Message 7 of 16
You should not need to change your user name for diagnostic test it follows thefirst test but you need to enter phone number. Test 3 need change username but don't want that test
i posted the btspeedtester link earlier
Message 8 of 16
Download speedachieved during the test was - 0.4
Mbps
For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
Additional
Information:
Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM),
0.45 Mbps(UP-STREAM)
IP Profile for your line is - 7.15 Mbps
Just run the test. is this what your looking for?
Message 9 of 16
Profile is correct but your download speed is below acceptable level - was test done wirelee or wired?
Message 10 of 16
