Message 1 of 2
Broadband speed very slow?
Just recently my broadband speed has dropped from 3.5mb download to less than 1mb. This makes doing anything almost impossible, this has been going on since Tuesday the 20th of November I thought I would leave it a few days before making a post to see if the speed would pick up but nothing, ive also tried resetting the hub a few times, also I have replaced the micro filter.
ADSL Line Status
Connection Information
Line state:Connected
Connection time:3 days, 15:06:18
Downstream:1.25 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Fast
Noise margin (Down/Up):16.8 dB / 24.0 dB
Line attenuation (Down/Up):41.0 dB / 21.5 dB
Output power (Down/Up):19.3 dBm / 12.3 dBm
FEC Events (Down/Up):0 / 3
CRC Events (Down/Up):5967 / 67
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):3268 / 8
Error Seconds (Local/Remote):2483 / 54
Results Image not loaded
1. Best Effort Test:  -provides background information.
 Download  Speed
 0.78 Mbps
0 Mbps1 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 0.78 Mbps
 For your connection, the acceptable range of speeds is 0.2 Mbps-1 Mbps.
 Additional Information:
 Your DSL Connection Rate :1.28 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 1 Mbps
Im not sure what steps i should take to get my internet back to its original state.
1 REPLY 1
Message 2 of 2
Re: Broadband speed very slow?
Hi
I am sorry to see you are having problems
I suggest you contact the forum mods they should be able to get your noise margin reset  for you this is a link to them http://bt.custhelp.com/app/contact_email/c/4951
They normally reply by email or phone directly to you within 3 working days they will take personal ownership of your problem until resolved and will keep you informed of progress
They are a UK based BT specialist team who have a good record at getting problems solved
This is a customer to customer self help forum the only BT presence here are the forum moderators
