Message 1 of 3
Broadband speed
Would be grateful for any help that can be provide on following:-
Been by customer for some years always has issue with BT TV mainly sport channels due to distance from main broadband line entering property and room where by box situated.  Many on line chats and 6 sets of by extenders later and an upgrade to halo 1 I was still getting issues of blocky tv or total signal loss.  I’ve now paid for a telephone socket to be put into room housing by TV set moved router and plugged straight into by tv box.  This has resolved by tv issue however I’ve found that my broadband speeds now nowhere near the upload or download guaranteed by bt halo, 8 mb off download and circa 1 off upload.  I’m afraid If i contact bt I’ll just be told to move the router back to main port, does anyone have any recommendations/ help?
thAnks in advance
2 REPLIES 2
Message 2 of 3
Re: Broadband speed
If you moved back to master socket and speed returns then it is an internal problem and if you get opreach then as internal you will get charged call out of £85
you need to look at the internal wiring and connections of the new socket you had installed
Message 3 of 3
Re: Broadband speed
Many thanks I’ll move router back to main broadband band socket and review soeeds
