greigster
Message 1 of 12
Broadband speeds and hub stats
Hi I hope someone can advise me.
I have been with BT for about 3 months now ans I thought I would get about 6mps down speed from the figures given when I signed up.
I dont understand the home hub stats but perhaps someone can tell if I am likely to get any faster speeds, here are the Speed test and Hub stats.
ADSL Line Status
Connection information
Line state:Connected
Connection time:44 days, 06:21:21
Downstream:3,851 Kbps
Upstream:1,087 Kbps
  ADSL settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Fast
Noise margin (Down/Up):2.8 dB / 5.5 dB
Line attenuation (Down/Up):47.5 dB / 23.2 dB
Output power (Down/Up):0.0 dBm / 12.8 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):141638 / 16444
Loss of Framing (Local/Remote):0 / 6
Loss of Signal (Local/Remote):4 / 6
Loss of Power (Local/Remote):0 / 0
Loss of Link (Remote):0
HEC Errors (Down/Up):256580 / 12313
Error Seconds (Local/Remote):0 / 10277
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
 Download Speed
 2.49 Mbps
0 Kbps4 Mbps
Max Achievable Speed
Download speedachieved during the test was - 2.49 Mbps
For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.
IP Profile for your line is - 3.4 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 914 Kbps
0 Kbps832 Kbps
Upload speed achieved during the test was - 914Kbps
Additional Information:
Upstream Rate IP profile on your line is - 832 Kbps
I had a similar problem at a previous address and the speed was improved by having interleaving resrored on my line. Am I righr in thinking that as my router stats/latency show "fast" this means that interleaving is switched off?
Thanks for any help.
Greigster
11 REPLIES 11
Message 2 of 12
Re: Broadband speeds and hub stats
are you connected to the master socket or the test socket?  do you have extension sockets in other rooms?
you can check possible speed here by entering your attenuation
check speed
greigster
Message 3 of 12
Estimation of your maximum rate adaptive adsl speed
Downstream
Attenuation
 dBApprox
Line Length
 km
dslMAX kbpsIP Profile kbps
adsl2+ (21CN) kbpsIP Profile kbps
adsl2+ (LLU) kbpsThroughput kbps
Dont know what this means. Connected to the test socket,I only have a master socket, there are no other phones/sockets in the house.
Message 4 of 12
worth checking  in case the front plate is  making a poor connection
Message 5 of 12
you are on adsl2+ and that on the kitz site when you enter your attenuation will give an estimate of your connection speed
Message 6 of 12
also try the quiet line test dial 147017070 and select option 2 you should here no noise if there is that needs reporting to BT Faults on 151 but do not mention broadband when you call
greigster
Message 7 of 12
There is no noise on the line and when I put in my attenuation figure of 47.5 it gives me a distance of 3.4 km from the exchange and an ip profile of 5500kbps, so why am I getting less than this?
Should I ask BT to put interleaving back on?
Thank for all your help guys
Message 8 of 12
you are on adsl2+and your connection speed should be nearer 6.4 mb your IP profile is related to your connection speed not the other way round
interleaving will not increase your speed
with your noise margin and attenuation you should be getting that and more
greigster
Message 9 of 12
Thanks for that, so what is my next move?
Message 10 of 12
Try this link http://www.btinternet.com/~cbeddoe/speed/Speed.html. You may find some useful hints
