SJH52
Message 1 of 6
Broadband still slow after line fault
Hi there,
Hope you guys can help me out Smiley Happy
On saturday 24/11/12 I lost my broadband/phone line the whole lot, i believe due to the rather unpleasent
weather that weekend.  I reported the fault, and on saturday 01/12/12 BT reported it as fixed, which was
correct, phone was working and as expected, broadband reconnected but slow.
Before the fault I would get speeds between 2000 - 4000kbps depending on time of day etc.
After the fault it was running at 572kbps and stayed here for a couple of days, although we were getting a lot of disconnects, the last one dropping the speed to 288kbps
I connected my router (its a netgear not a bt home hub) straight to the test socket and has now been stable for 3 days but no increase in speed as of yet.
My only concern is that using the BT speed tester it says the maximum speed for my connection is 0.25mbps??
Do i need to leave it connected for a couple more days?  Anything else I need to try first?
Stuart
Router:
WAN up time  :   3 days 00:18:07
TxPkts  :  433707
RxPkts  :  535261
Collisions  :  0
Tx B/s  :  228
Rx B/s  :  1706
Connection speed down/up  :  288kbps/956kbps
Line attenuation down/up  :  50.0db/26.3db
Noise Margin down/up  :  5.2db/6.3db
BT Speed Test
Download speedachieved during the test was - 0.19 Mbps
 For your connection, the acceptable range of speeds is 0.1 Mbps-0.25 Mbps.
 IP Profile for your line is - 0.25 Mbps
Upload speed achieved during the test was - 0.82Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.83 Mbps
5 REPLIES 5
Message 2 of 6
Re: Broadband still slow after line fault
I would suggest you let the connection continue until 5 days have been completed then post back
SJH52
Message 3 of 6
Ok, will report back in a couple more days.
Regards
Stuart
SJH52
Message 4 of 6
Hi again,
Reporting back after 5 day connection, still no improvement 😞
WAN up time  :   4 days 23:58:07
TxPkts  :  710094
RxPkts  :  844184
Collisions  :  0
Tx B/s  :  227
Rx B/s  :  1503
Noise Margin down/up  :  5.8db/6.0db
BT Speed Test
Download speedachieved during the test was - 0.17 Mbps
Upload speed achieved during the test was - 0.88Mbps
Is it worth rebooting my router at all?
Stuart
Message 5 of 6
Hi
I am sorry to see you are having problems still dfo not restart the hub
I suggest you contact the forum mods they should be able to get this problem sorted for you this is a link to them http://bt.custhelp.com/app/contact_email/c/4951
They normally reply by email or phone directly to you within 3 working days they will take personal ownership of your problem until resolved and will keep you informed of progress
They are a UK based BT specialist team who have a good record at getting problems solved
This is a customer to customer self help forum the only BT presence here are the forum moderators
SJH52
Message 6 of 6
Thanks for the reply, will contact them with the details.
Just my luck as reading that I shouldn't restart the hub the connection dropped anyway!!!! 😞
Has still reconnected at the same speed though.
Will report back with results
Stuart
