Newbie
Message 1 of 11
Broadband suddenly unusable in the evenings
Hi all - first post, please be kind!
Recently (last week) my broadband download speeds have become incredibly slow in the evenings, to the point that the BT speed test will time out. When it does run, I get approx 0.1-0.2 Mbps download (but bizarrely, my usual 1Mbps upload speeds). It seems intermittent as well (rather than slow and consistent!).
There is no significant noise on the line.
At this moment (plugged into the test socket) I get 9.96Mbps to the house, but only 4.41Mbps to the computer (over wifi).
I'm on a HomeHub 3. My diagnostics (before and after test socket) are as follows:
BEFORE
After 10 minutes on the test socket:
I have no idea what these stats mean, is there anything obviously wrong with my connection?
Is 4.5 million FEC events and 33,000 HEC errors acceptable in a 13 minute period?
Any help appreciated.
Cheers,
Sam
10 REPLIES 10
Newbie
Message 2 of 11
Re: Broadband suddenly unusable in the evenings
Speed test:
Download speedachieved during the test was - 4.96 Mbps
 For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
 IP Profile for your line is - 8.78 Mbps
Message 3 of 11
Try quiet line test. Dial 17070 option 2. Should be quiet and best done with corded phone. If cordless dull hum normal. Can you re-run the diagnostic test but this time with a cable connection instead of wifi as wifi is prone to interference. Don't restart router before test
Newbie
Message 4 of 11
Cheers.
I've done the quiet line test, and couldn't hear any noise I wouldn't expect from a cordless handset (I don't have a corded phone).
My wired stats are as follows...
Download speed to the computer are still only 3.75Mbps with speed to the home of 9.96Mbps.
Message 5 of 11
You have a lot of errors for only 1+hr connected. Even with cordless should at worst only be a dull hum anything else is a problem
If you are still in test socket can you post the diagnostic results using an ethernet cable
Newbie
Message 6 of 11
I can hear very faint noise on the quiet line test. Like static noise. I wouldn't put my neck on the line and say it was any more than a wireless handset would do by itself though, but I'm no expert. No humming that I can hear.
The figures in my post above are on ethernet through the test socket... are there any other diagnostics I can run that I don't know about?
Message 7 of 11
You need to post the full results. If your download speed using cable is below the acceptable limit then mods will help but needs to be with cable and full results
Newbie
Message 8 of 11
It's back up to speed now, so will have to try again tomorrow evening when it slows down to a standstill again. My current results on ethernet through the test socket...
Message 9 of 11
6.2mb download on 8.78mb profile is fine. If you post when it drops but needs to be using cable
Have you tried changing the wifi channel?
Newbie
Message 10 of 11
It dropped to 0.1Mbps earlier this evening Smiley Frustrated
Looks like I'll be back tomorrow! Cheers for the help this evening though.
