soggy
Message 1 of 37
Broadband very slow
Hi BTcare
Here,s my problem my internet speed has been really slow lately and i contacted BT about it and they tried to help by telling me to restarting the home hub stuff like but it didn,t help. So they sent BT Openreach to test the line wihich they said was okay around 1mb but they changed the master socket to a new one with built in filter. Also asked them could it be the home hub thats faulty so i decided to get a new home hub 3 and a cat5 rj11 cable which he recommended and fitting today to see if it helps.
But i,m still getting slow speed around 105kb i know that it hasn,t been up long to see if it gets better but even when it was working before this i only got 210kb. Can anyone make sense of this please.
36 REPLIES 36
imjolly
Message 2 of 37
Re: Broadband very slow
can you run btspeedtester and post the results  http://speedtest.btwholesale.com/  when first test finishes run diagnostic test and post results
soggy
Message 3 of 37
imjolly
Message 4 of 37
it was the next test after that test completed - diagnostc test.  however looking at download speed that is higher than I expected with your connection speed and probable profile
soggy
Message 5 of 37
posted the other test for you mate
imjolly
Message 6 of 37
just as said your profile is ok and download also ok for your connection speed.
try quiet line test  dial 17070 option 2  should hear nothing and best with corded phone   if cordless dull hum is normal
also check this post for some ideas
http://community.bt.com/t5/BB-in-Home/Poor-Broadband-speed/m-p/14217#M8397
soggy
Message 7 of 37
Done the test didn,t hear anything also if i,m getting 1mb should i be getting download speed close to that.
Thanks for replying
imjolly
Message 8 of 37
you have a download speed of 1mb but most sites show kbps and with your speed that is probably about 120/125 or slightly less
soggy
Message 9 of 37
I was getting 210kbps not great but learned to live with it but what ever happen the speed has halved
imjolly
Message 10 of 37
the problem is your connection speed is lower than before but with noise margin of normal 6db there is little scope for improvement
the filtered faceplate is normally the best connection for your broadband - are you using an extension cable to connect your router?
