soggy
Message 11 of 37
Re: Broadband very slow
no it just a cat 5 rj11 cable from socket to hub and ethernet cable from hub to pc
imjolly
Message 12 of 37
soggy
Message 13 of 37
Its similar to this one on this link
10m CAT5E- external adsl Broadband cable RJ11
imjolly
Message 14 of 37
ok
is it possible to connect to the test socket instead of the filtered faceplate to see if that makes any difference to your connection speed/noise margin.  this is just to check as it should be very similar connection
soggy
Message 15 of 37
so do i connect the phone and internet cable via a filter to the test socket
imjolly
Message 16 of 37
yes filter then router and phone if you can that would rule out that as a problem  - then repost router stats
soggy
Message 17 of 37
imjolly
Message 18 of 37
slightly higher connection speed and a better noise margin
was there anything which helped inthe link I posted previously especially if running a long rj11 cable
soggy
Message 19 of 37
not really only thing that my master socket is below a radiator don,t if that is the problem but its always been there.
imjolly
Message 20 of 37
don't think that will cause a problem.  if you can leave it for a day or so and then repost new stats and see if stable
