Ian1957
Message 31 of 181
Re: Broadband wireless can't connect:
Could you run a speedtest on speedtester.bt.com? I would be interested to see if your ip profile has risen.
And even though the wireless channel is on 13, the connection still drops? 😕 is this with the laptop or the xbox?
Also are you using the HomeHub2 or 3?
Adam1992
Message 32 of 181
I'm using the Hub 3
My laptop wouldn't connect from a few feet away a minute ago, haven't even tried xbox. I will run speed test now if everything stays connected.
Ian1957
Message 33 of 181
When you run the speedtest, is it possible that you could do it when your are connected to the hub via Ethernet cable. Also make sure the only device connected is the one you perform the speedtest on and that the only application on your PC that is running is the Internet browser and the only tab you have open is the speedtest one.
I have something we can try bt I would like you to perform the speedtest first. 🙂
Adam1992
Message 34 of 181
Oh dam I ran it wirelessly, you want me to run the other speed test from London server on ethernet?
my results: technical issue couldn't test upload
Results Image not loaded
<script type="text/javascript">// paintProgressAndMessageOnBar(100,"The test has successfully completed"); // </script>
Test1 comprises of Best Effort Test: -provides
background information.
 Download  Speed
 6566 Kbps
0 Kbps21000 Kbps
Max Achievable Speed
Download speedachieved
during the test was - 6566 Kbps
For your connection, the acceptable
range of speeds is 4000-21000 Kbps.
IP
Profile for your line is - 16978
Kbps
If you wish to discuss these
results please contact your ISP.
If you are experiencing problems with specific applications, servers or
websites please contact your ISP for assistance.
Your test has completed please close this window to exit the performance
tester.
Note: An Upstream test was not conducted on
this line due to a technical issue. If your concern is related to upstream
performance then please retry
the performance test again in 1 hours
time.
Please visit FAQ
section if you are unable To understand the test results.
Ian1957
Message 35 of 181
Yes please perform the test at speedtest.net via Ethernet 🙂
Ian1957
Message 36 of 181
Also, do you still have your Home Hub 2?
Adam1992
Message 37 of 181
Ok will do the test now via ethernet.
Yes I think we still have the HH2
Adam1992
Message 38 of 181
Via Ethernet:
Ping - 15ms
Download - 16.43
Upload - 0.94
Ian1957
Message 39 of 181
There is absolutely nothing wrong with your broadband line, it is excellent!
Was there a problem with your home hub 2 or did you just use the hub 3 because it is newer? 🙂
Ian1957
Message 40 of 181
If I may suggest, If it isn't too much trouble, that you use the home hub 2 instead of the 3 and see what the wireless range is like then. I have read that there is problems in the firmware for the home hub 3. 🙂
