Adam1992
Message 81 of 181
Re: Broadband wireless can't connect:
Latest results:
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 02:14:03
Downstream:19.38 Mbps
Upstream:1.154 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Interleaved
Noise margin (Down/Up):2.4 dB / 6.0 dB
Line attenuation (Down/Up):25.2 dB / 14.1 dB
Output power (Down/Up):20.0 dBm / 12.2 dBm
FEC Events (Down/Up):2705187 / 42
CRC Events (Down/Up):672 / 32
Ian1957
Message 82 of 181
Did you restart the hub or did it drop signal and therefore resync? Is your wireless working yet? Other than that your line stats are **bleep** good!
Adam1992
Message 83 of 181
No this is through my Hub being back upstairs and plugged in through ethernet 😞
Results of Speedtest through Ethernet:
EDIT - I'm back on Ethernet through the Home Hub 3.0 back upstairs, still not practical 😞
1. Best Effort Test: -provides background information.
 Download  Speed
 14715 Kbps
0 Kbps21000 Kbps
Max Achievable Speed
Download speedachieved
during the test was - 14715 Kbps
For your connection, the acceptable
range of speeds is 4000-21000
Kbps
Additional Information:
Your DSL Connection Rate
:19846 Kbps(DOWN-STREAM), 1181 Kbps(UP-STREAM)
IP Profile for
your line is - 17000 Kbps
2. Upstream
 Upload Speed
 910 Kbps
0 Kbps1181 Kbps
>Upload speed
achieved during the test was - 910 Kbps
Additional
Information:
Upstream Rate IP profile on your line is - 1181
Kbps
Adam1992
Message 84 of 181
By the way as I haven't a clue I see some peoples downloads and Uploads are capped?
Are my downloads and Uplaods capped? what is SNR also? what is the number for line noise etc as I want to check all possibilities if possible.
Ian1957
Message 85 of 181
Your line speeds are not capped and there is nothing wrong with your SNR, your line stats are perfectly good. The problem lies in that the wireless signal broadcaster seems to be faulty which is a fault within the hub itself
Adam1992
Message 86 of 181
Ohh ok, I was just asking as these questions seem to crop up in other threads. Thanks for clearing that up, by the way how is it you know all on BT Hubs and Broadband connections as this place seems to have been my best place for help anywhere.
Ian1957
Message 87 of 181
Well u gained most of my knowledge around this time last year when I came to the forums looking to increase my speed, lower my SNR and get my line change from adsl max to adsl2+ 21CN BTW, I was given lots of advice, I started to contribute in other threads, there were links given that I would read, and if I didn't understand something I would go and research it 🙂
Btw, you dint happen to have wireless router to hand that isn't a bt home hub do you?
Adam1992
Message 88 of 181
Oh right, must have been loads of reasearch over many months 🙂 .
No I don't sorry, I only have HH2 and HH3 of which both seem faulty as previously said 😞
Your son has been helping me also, it is weird to talk to someone around my age who has a vast knowledge of Computers etc. Most Teens I'm 19 still have basics on computers but when you get to nitty gritty we have no idea :(.
Back to your question, sorry I don't have any routers that aren't BT's. If need be I can ask around?
Ian1957
Message 89 of 181
It's still Ian's son, Nathan 🙂 haha, my dad knows nothing about the Internet :') . I'm 16 btw, start 6th form next tuesday.
If you have any friends or neighbours that would be happy to let you borrow a wireless router to test then that would help give you more evidence for a faulty hub 🙂
Adam1992
Message 90 of 181
Oh Hi Nathan 🙂
Yeah I will ask my next door neighbours etc if they have a spare router I can test, highly unlikely but I can only try.
I do have a mate who is going into IT business so he may be a good shot for me 😉
