Message 1 of 6
Broken Home Hub 4 - Type A
Hi all,
a bit new to this, and just have a qucik question.  We have a home Hub 4 type A that got damaged when we spilt a glass of water on it.
Can i simply buy a new one?
will i be able to plug it in to the white open reach box? and will it work? or do i have to have the home hub registered with bt?
Alternatively can any one recommend an alternitive that will work?
Many thanks
TomSmiley Happy
5 REPLIES 5
Message 2 of 6
Re: Broken Home Hub 4 - Type A
you can use any hub/router you wish it does not have to be a BT hub
Message 3 of 6
Great John.
thanks very much. can you recomend a good one?
thanks again
Tom
Message 4 of 6
are you on infinity or normal broadband
Message 5 of 6
many on the forum have changed to the tplink 9980 modem/router which will work on both adsl and fibre connection
Message 6 of 6
If the router that you buy does not set its self up automatically you will need to enter bthomehub@btbroadband.com as the username and you can use anything for the password. Most people just use BT.
