Distinguished Guru
Message 31 of 105
Re: Forum oddness
Thanks Kerry.
At least I can put my magnifying glass awaySmiley Very Happy
Also I'd rate your post but as we all know, the facility isn't thereSmiley Sad
Maybe if new sections are added then presumably this thread could be moved and I will be able to do soSmiley Indifferent
-+-No longer a forum member-+-
Distinguished Guru
Message 32 of 105
Re: Thriving Forums - Security Issue - Mod to check?
These Thriving Forums have changed recently in many ways.
Having popped on here within the last week, I noticed that these Forums no longer appear to be fully tested by the BTNP AV software (McAfee). It now shows the "?McAfee SiteAdvisor" in the grey box instead of the normal tick and green box. You may wish to investigate this.
Distinguished Guru
Message 33 of 105
A BTNP update was allowed by myself 5 mins ago and at this present time BTNP shows that all areas of these thriving forums are now back to green (ticked).
The above post is solved - but was this a routine update. Anyone care to comment?
Distinguished Guru
Message 34 of 105
Re: Forum Oddness
Who forgot to put 50p in the meter!Smiley SurprisedSmiley Very Happy
52i01659D078CC27EE4
Message 35 of 105
Re: Forum Oddness
@ DS, thats funny, I've had that one as well.  I'm sure it was 1/- though and not 50p Smiley Wink
AQ.
"Welcome to Royston Vasey - You'll never leave."
Distinguished Guru
Message 36 of 105
Re: Forum Oddness
52i01659D078CC27EE4
This is really starting to pee me off!!Smiley Mad
Is this at my end??
Having said that no other site has a problem with this and it's happened that many times this evening I've lost count.
Is there a problem with the server (ie overloaded).
Any advice would be good.
Community Manager - Retired
Message 37 of 105
Re: Forum Oddness
Hi DS
Sorry you are having problems with this.  We haven't experienced this fault but I'll drop you a PM asking for some details about your individual setup so we can log with the Tech team.
Thx
Kerry
Retired BTCare Community Manager - StephanieG and SeanD are your new Community Managers
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
Distinguished Guru
Message 38 of 105
Re: Forum Oddness
Hi Kerry
PM sent
Distinguished Guru
Message 39 of 105
Re: Forum Oddness
Hi Kerry
Cancel the bit about only getting the above error.
Had this since 8pm(ish)
125i23086D3DC78716BC
Distinguished Guru
Message 40 of 105
Re: Forum Oddness
Twice in the last 24 hours I've been typing a reply to a post when for no apparent reason, above the Post message window a message in a pink box states "Sorry, unable to complete the action you requested" is displayed.
Why?
It can't be at my end as it's happened on 2 different PC's
