Message 1 of 23
Bt Home Hub 3 and WPA
Hi everyone,
I recently have the home hub 3 and it's working fine for 6 hours and then I can't connect to it : it says time-out.
But when i change the security to wep instead of wpa or wpa2, everything is working great. I really would not like to have wep for security, so do you know any solution to this problem ?
22 REPLIES 22
Message 2 of 23
Re: Bt Home Hub 3 and WPA
See some hints here Wireless Help
Try WPA only, not WPA/WPA2
Message 3 of 23
Tried it, but it doesn't work. It seems that just wep seems to work, even if my airport extreme works great even in wpa2
Message 4 of 23
@GreatGold wrote:
Hi everyone,
What device will not connect?
Message 5 of 23
All of my devices: iphone, macbook pro, ipod touch. But the problem is the home hub because for the first six hours it worked great, then no more.
Message 6 of 23
Have you restarted the hub to see if it makes any difference?
Message 7 of 23
I pushed for 15 second the restart button and the problem was still there. I really don't know what to do next
Message 8 of 23
Do you have another wireless router?
Distinguished Guru
Message 9 of 23
Hmm, odd for sure.
Did you ever connect the devices using the WPS facility?
You could try the following:
Delete the hub details from all of your devices
Unplug the hub from the BB, then carry out another (15 second) factory reset.
Then connect a laptop/PC via ethernet and manually turn off WPS (you could also make any other changes ie wireless SSID etc)
Connect the devices to the hub
Reconnect the hub to the BB
See what now happens....:|
That's all I can offer on this
-+-No longer a forum member-+-
Message 10 of 23
Its beginning to look like a faulty home hub 3.
