gc28
Message 1 of 17
Bt Infinity 2, A loss of 10mbps
Over the last 3 days i've lost significant speed, I was reciving 23mpbs as a standard.
I've tested
via eithernet
in safe mode
iphone
restarting box
I've have also looked at netstat's and that looks fine
so any ideas??
[URL=http://www.speedtest.net][IMG]http://www.speedtest.net/result/2564578094.png[/IMG][/URL]
16 REPLIES 16
Message 2 of 17
Re: Bt Infinity 2, A loss of 10mbps
could you please run the diagnostic test on the bt speedtest
http://speedtest.btwholesale.com/ so we can see your IP Profile also what was the speed you were quoted when you ordered infinity
gc28
Message 3 of 17
I have just ran it, it's given me roughly the same results as speedtest.net
and i was quoted and recived 23mbps
Sage
Sage
Message 4 of 17
John wants you to run the further diagnostics  then copy and paste the result here.
gc28
Message 5 of 17
is the Service ID needed? and can i find it without calling?
gc28
Message 6 of 17
FAQ
Results Image not loaded
1. Best Effort Test:  -provides background information.
 Download Speed
 10.09 Mbps
0 Mbps10.1 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 10.09 Mbps
 For your connection, the acceptable range of speedsis 16 Mbps-10.1 Mbps .
 Additional Information:
 IP Profile for your line is - 10.1 Mbps
2. Upstream Test:  -provides background information.
 Upload Speed
 1.09 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 1.09Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
The test result has indicated that you should contact your ISP for further assistance.
Please visit FAQ section if you are unable To understand the test results.
Guru
Message 7 of 17
When did you have Infinity installed?
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
gc28
Message 8 of 17
ermm around 8 or 9 months ago, no problems until this
Guru
Message 9 of 17
Ok
Can you ring 17070, you are doing this to see if you can hear any noise. If you can post back here, if it's crystal clear post back here as well.
gc28
Message 10 of 17
i don't have an analog phone but i'll try and sort one
