Message 1 of 7
Bt Infinity 2 getting slower
Been having an issue with our speed over the las 6 month we used to get a contstant 66mb we had a recent issue where we were only getting in the 30-40mb but each time we call we are told they will run tests and we need to monitor the line is there anything we can do to get our speed back up ???
Product name:
BT Hub 6A
Serial number:
+084319+NQ61939976
Firmware version:
SG4B1000B316
Firmware updated:
30-Jul-2017
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 4 Hours 55 Minutes 17 Seconds
Data rate:
15.00 Mbps / 55.00 Mbps
Maximum data rate:
19002 / 66332
Noise margin:
8.7 dB / 8.9 dB
Line attenuation:
17.1 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
2007 MB Uploaded / 3063 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Not active
2.4 GHz wireless network name:
SmileyouronCCTV
2.4 GHz wireless channel:
Smart (Channel 6)
5 GHz wireless network name:
SmileyouronCCTV
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
90:4D:4A:0A:45:1D
Software variant:
Boot loader:
7.33.1
6 REPLIES 6
Moderator
Moderator
Message 2 of 7
Re: Bt Infinity 2 getting slower
Hi @tashle101 and welcome.
Your connection DSL uptime shows 0 Days, 4 Hours 55 Minutes 17 Seconds. have you been resetting the hub? If so you need to leave it connected to allow DLM to take action.
Cheers
David
Message 3 of 7
Had to move the hub so had no option other to turn off.
Moderator
Moderator
Message 4 of 7
Thanks for confirming that @tashle101.
Can you try leaving it connected for a few days and post back to let me know if there is any change?
Cheers
David
Message 5 of 7
Yes no problem which post results middle of next week
Thank you
Message 6 of 7
dont seem to be any change
Message 7 of 7
Speed bad tonite
