Herrschmitt
Message 1 of 6
Bt Infinity 2 is it worth paying extra when Infinity 1 is upgraded ?
Hi All,
I am a BT infinity 2 customer, i presently get around 58-60 mb Download speeds, The question i have is , Is it worth continuing paying for Infinity 2 when Infinity 1 is upgraded to Up to 76Mb ? Is Infinity 2 going to be upgraded in near future. any info greatly appreciated. thank you .
5 REPLIES 5
gg30340
Message 2 of 6
Re: Bt Infinity 2 is it worth paying extra when Infinity 1 is upgraded ?
If you look through the forum you will find a few other threads asking the same as you.
Short answer is no unless you want the extra Cloud storage and extra BT/McAfee antivirus licences.
licquorice
Message 3 of 6
It wasn't worth it before if you are only getting 58-60 as Infinity1 max is 55 and you would never tell the difference.
Infinity1 is not 'upgraded to 76Mb' just the cap is removed, your speed won't increase. It won't matter if Infinity2 is 'upgraded' (which I doubt) you will only be able to get the speed your line is capable of (58-60)
Herrschmitt
Message 4 of 6
Hi. Thank you to all those who replied to my enquiry. Seems i might just as well downgrade to infinity 1 and pay less per month.
annegray01
Message 5 of 6
I'm supposed to get up to 76 and I get 35 !
gg30340
Message 6 of 6
Just because you are on Infinity 2 with an "up to 76Mbps" does not mean your line can support those speeds. You will only ever get the speed your line can support regardless of what package you are on.
If you think you are not getting the speed that was estimated for your line when you checked prior to signing up for Infinity 2 you should start a new thread outlining what the problem is and somebody should offer some assistance to establish if there is a problem and how to resolve it.
