Message 1 of 8
Bt Infinity 2
Hi
My service, bt infinity 2 was activated today, i am connecting at just over 52 mbps, much lower than my estimated 63mbps, i know the connection has to stabilize over the next 10 days, but is it usual for it to go up during this period ?, i tried resetting my router, but it just connected at a lower speed of 50mbps, any advice would be welcome.
Cheers
Paul
7 REPLIES 7
Message 2 of 8
Re: Bt Infinity 2
You must leave it alone for 10 days, resetting it will be seen as a fault, and will lower your speed.
Which BT Home hub do you have?
Message 3 of 8
Re: Bt Infinity 2
The 10 days is a myth, even more so on FTTC.
Message 4 of 8
Re: Bt Infinity 2
Hub is the smart hub
Message 5 of 8
Re: Bt Infinity 2
In order to find out what services and speed range you should be getting, please enter your phone number into this form.
Broadband availability checker
Please remember to edit out your phone number before you post the results.
Please post the information from the smart hub, using this link.
http://192.168.1.254/0000012803/gui/#/technicalLog/information
Message 6 of 8
Re: Bt Infinity 2
Message 7 of 8
Re: Bt Infinity 2
Message 8 of 8
Re: Bt Infinity 2
