Prh66
Message 1 of 16
Bt Infinity 2
Hi
Looking for some advice. About 3 weeks ago i reported a fault on my landline, which had bad crackling. BT sent out an engineer and the fault was fixed at the cabinet end. My Infinity 2 speed was always around 55-62 mbps it then dropped to 44mbps after the fault was repaired and has stayed that way for the past 2 weeks, despite me reporting this and another engineer visit to the cabinet today.Could the engineer have set something wrong ?as i now have infinity 1 speed and not my regular speed. Also when i now run an estimated speed test it shows an estimate of much lower than it showed when i first ordered Infinity 2.
Paul
15 REPLIES 15
john46
Message 2 of 16
Re: Bt Infinity 2
Can you use this speed tester then carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down.
This test must be done with a wired connection.
http://speedtest.btwholesale.com/
Prh66
Message 3 of 16
Re: Bt Infinity 2
Hi
Prh66
Message 4 of 16
Re: Bt Infinity 2
Hi
Tried again with a different browser
Webby
Message 5 of 16
Re: Bt Infinity 2
Can you post hub stats and a screenshot of the results for your number using https://www.dslchecker.bt.com
Prh66
Message 6 of 16
Re: Bt Infinity 2
Prh66
Message 7 of 16
Re: Bt Infinity 2
Hi
Anyone offer any advice ? it looks like my line no longer supports Infinity 2 since fault was fixed?.
PaddyB
Moderator
Moderator
Message 8 of 16
Re: Bt Infinity 2
Hi @Prh66,
If you send me in your details, I'll be able to take a look at your connection and run a few checks on your line.  You can send me in your details using the "Contact The Mods" link found in my profile?
PaddyB
Prh66
Message 9 of 16
Re: Bt Infinity 2
Hi Paddyb
What details do i need to send you ?.
licquorice
Message 10 of 16
Re: Bt Infinity 2
Click on the 'Contact the mods' link and complete the form.
