Hi i had infinity up to 52mbps installed last wednesday was getting 52 mbps down then it dropped to 45mbps im getting 53meg maximum data rate with about 6.2db noise sometimes dropping to 5.8 down/up my sync speed stays the same but the maximum data rate goes all the way to 57 mbps sometimes am i maxed out or can it be sorted ? also the last 3 days my smart hub restarts at 5pm then at about 8 and 10 pm what do you think this is as its everyday ? cheers
Solved! Go to Solution.
no i only have a hub 3 and 4 but no modem so cant use them on fibre
miles better now cheers
