Message 1 of 3
Bt Mini Connectors
Hi
I ordered BT TV the other day and before check out was given the option to add mini connectors for self-install for£10. Each time I arrived at the shopping cart the mini connectors hadn't added....tried a few times. Anyhow I went through with the order.
Now it seems these connectors are 80 odd quid. Any chance getting them for the original price?
2 REPLIES 2
Message 2 of 3
Re: Bt Mini Connectors
Hi @thenewno2, the BT TV helpdesk will be able to order them at the reduced rate if you give them a call on 0800 800 150.
Message 3 of 3
Sorted. Cheers mate
