Message 1 of 14
Bt Retail Servers Fault
I recently upgraded from Infinity 1 (52mb/10mb) to Infinity 2 (76mb/20mb). We are close to the cabinet and got 15mb down on ADSL. The upgrade was good as we got 50mb down and 10mb up so pretty much right on the top speeds. We have a clean line with no extensions and straight into the master socket.
Since we upgraded to infinity 2 we get 71mb down, but still only 10mb up. We also now have an open fault on the line that has been there since we upgraded. I'm therefore guessing the fault is with our upload speed. It says the fault is with the Retail Servers.
I have spoken to the Indian call centres and the assistance they give is utterly woeful and they don't even seem to understand the basics of the broadband service.
It isn't lost on me that I'm getting a speed most people only dream of, but if I'm able to get 18mb up and am paying for it then surely I shoudl get this and not have a fault on the line. After all, psting pictures of my tea to myspacebook is much quicker with a fast upload....
I'd be grateful for any help
13 REPLIES 13
Message 2 of 14
Re: Bt Retail Servers Fault
if you have a Homehub 5 can you also post the stats from 1-12 by logging onto the homehub management pages then troubleshooting > helpdesk. http://bthomehub.home/
The stats for the Home Hub 6 can be found on the Information page from http://192.168.1.254 then Advanced Settings -> Technical Log.
Can you run this checker and post back a screen shot of the results. Make sure you delete your phone number before posting.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
Can you use this speed tester then carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down. This test must be done with a wired connection.
http://speedtest.btwholesale.com/
Message 3 of 14
Hi,
Many Thnanks for replying.
Here is the homehub stats picture:
and the Wholesale ADSL checker results:
Here are the speedtest and diagnostics results. Ping Latency was 33.38ms. The upload speed of 10mb is what we have been getting constantly since the upgrade. The download of 69 is slightly down today as we've been getting 71 - 72 over the last day or so:
Thanks for your time,
Dave
Message 4 of 14
Is the speed test using a wired or wireless connection? Your upstream is syncing at the maximum 20Mbps.
Message 5 of 14
Speedtest was done using a wired connection
Message 6 of 14
upload speeds are not guaranteed and can be anything up to 20 Mbps there can be many reasons for low upload speed normally noise in the upload frequency range which can be hard to trace
Message 7 of 14
Download speeds constantly vary due to network activity
Message 8 of 14
Its not noise, the OP is syncing at 20M with headroom. It appears to be a network problem.
Message 9 of 14
the noise I was referring to was that that would affect the upload frequency range not the type of noise that affect sync speeds
close range to some power supplies can affect upload speed worthwhile separating power supply leads and signal leads this is an old ADSL link but the posted suggestion can help http://community.bt.com/t5/BB-Speed-Connection-Issues/Poor-Broadband-speed/m-p/14217#M8397
Message 10 of 14
Sorry John,noise that affects the upload frequency range will affect upload sync speed. Noise can't impact directly on upload speed, it acts on the DSL level.
