conlap15
Message 1 of 7
Bt Sport not working on Safari or firefox?
Hi
I recently set up my BT sport but i am unable to view anything on safari or firefox.  with safari i just get a black screen after i select a programme to watch.  With firefox i can choose the programme and click watch it tries to load but nothing else happens.  I tried it on internet explorer and it works however picture seems very fast?  any tips on how to get it working on safari.  I am using a laptop.????
6 REPLIES 6
Ectophile
Distinguished Guru
Message 2 of 7
Re: Bt Sport not working on Safari or firefox?
Check the Microsoft Silverlight page http://www.microsoft.com/getsilverlight/Get-Started/Install/Default.aspx
You need a compatible operating system and web browser, and you need the appropriate plug-in for that web browser.
I have had BT Sport running on Firefox under Windows 7.
conlap15
Message 3 of 7
Hi
I have 64 bit silverlight installed on my laptop and I use windows 8 surely this should work?  only works on my internet explorer.
legitimise_sailing
Distinguished Expert
Message 4 of 7
Yeah works for me
To say thanks for a helpful answer, please click the white star
conlap15
Message 5 of 7
hi
still not working just a black screen any tips on how to get it working, what are the plug-ins?  sliverlight is installed correctly
legitimise_sailing
Message 6 of 7
Update your video card drivers
Set your clock to 24 hour format and the correct time
Run the Silverlight fixit http://support.microsoft.com/kb/2608523
blownfuse
Message 7 of 7
Install Goggle Chrome. Your problem was exactly the same as mine. I don't use Windows IE. Never worked. With Chrome
it's picture perfect.
Regards
