Message 1 of 8
Bt WiFi Hotspot log in
I can't log into BT WifI hotspots from my laptop. WHen I try and log in it says my username and/or password are incorrect. However I know I am using the correct username and password as I can log onto MyBT with them. Have you got any suggestions of how to fix this.
7 REPLIES 7
Message 2 of 8
Re: Bt WiFi Hotspot log in
Are you the BT Broadband account holder?
Have you tried looking trough the BTWifi help pages?
Get wireless Internet | Find wi-fi hotspots | BT Wi-Fi (btwifi.co.uk)
Message 3 of 8
Yes I have tried to log in correctly every time it will just not recognise my username and password. I have had this problem for months now and myself and none of those of my household can log into the BT Wifi hotspot using the same log on details that I can log into MtBT with. Its very frustrating.
Message 4 of 8
Have you tried connecting to your own BTWIFI either just selecting available networks or by using the BTWIFI app.
By chance did you have a previous btyahoo email?
Message 5 of 8
What happens if a user has opted-out of BTWiFi and tries to login?
Message 6 of 8
Yes I can log onto my opwn BT WIFI network at home. However when I'm away from home I am trying to log onto BT wifi from a laptop so no app is available. I have never had a btyahoo email.
Message 7 of 8
So can you log into your hub BTWIFI using the laptop?
Message 8 of 8
I can't log into hot spots using the "my BT" log in information BUT I can using one of my email addresses name and password, strangely not my primary email address so it is worth going through your bt email addresses.
