Message 11 of 13
Re: ARe: Bt broadband dropping, anyone experiencing same
Should have said thanks for the info on resetting, having said that it’s the only thing that works!
Message 12 of 13
@Shimmy
this is BTs launch of Halo 1 & 2   as you can see it is just the BT Hub with Halo as an extra not a different hub
https://newsroom.bt.com/bt-launches-halo-the-uks-ultimate-converged-plan--giving-customers-the-best-...
Message 13 of 13
It doesn’t really matter to me what’s its called, it just does not work as it should
