Message 1 of 5
Bt home hub 3 speed drops when connected to Ethernet?
hi
when i am using my bt home hub 3 on wireless everything is fine. the speed is about 10mbps witch is about right. but as soon as i plug in anything to do with Ethernet. my connection drops and i can not access the internet wired or wireless intill i unplug the Ethernet cable. This must something up with the bt hub as i have set up one of my old belkin hubs to work on bt broadband and the connection is fine when i use ethernet.
Anyone know whats up?
4 REPLIES 4
Message 2 of 5
Re: Bt home hub 3 speed drops when connected to Ethernet?
welcome to the forum
have you checked to make sure that your network card drivers are up to date - check manufacturers website
does it happen with all the ethernet ports
Message 3 of 5
thanks for the fast reply. yes all my drivers are up to date. I have tryed all the ports on the hub but same result. it heppend if i plug my ps3, desktop or laptop in, they also all work fine with my belikn
Message 4 of 5
sounds like a faulty HH3  need to contact CS India for replacement
08001114567
Message 5 of 5
just my luck to get a faulty one,
thanks for your help will give them a call now to get a new one.
