Sage
Message 11 of 16
Re: Bt homehub 5 event log ?
If it's not causing any issues why worry? It's just a normal firewall log. Your HH3 nay not have been configured to show all events, just important ones.
Message 12 of 16
It's not causing any issues that I know about but as I said before had hh3b for 6 months and never had any logs as bad as the hh5 just was a bit concerned what was causing them that's all going from no events to pages of events in days ?
Message 13 of 16
as already been posted just ignore it
Message 14 of 16
@gg30340 wrote:
If you opt out of BTWifi you will not be able to use the free BTWifi hotspots when you are out and about.
Does data transferred via your hub on BTWifi count as part of your data usage?
Distinguished Guru
Message 15 of 16
No, you can use your own BT Wifi hotspot to avoid counting your own usage.
If not, I'll try again 🙂
Message 16 of 16
you are posting on a year old post which is not related to the recent hub problems
