Message 11 of 14
Re: Bt hub badly placed
@Bjscc1989 wrote:
Any advice on what cable to buy?
It depend on how long you need it. There are plenty available from many retailers. Whichever is easiest for you.
Message 12 of 14
You can get a cat5e 10 metre cable for about £5 from ebay.
Message 13 of 14
Does anyone know if it affects the speed at all, buying a 10 meter ethernet cable?
Message 14 of 14
No, provides it good quality with all wires connected.
