legitimise_sailing
Distinguished Expert
Message 31 of 43
Re: Bt infinity 2 DLM
Is that a plasma? Try keeping the Homehub away from electrical devices.
To say thanks for a helpful answer, please click the white star
thomasmulhall
Message 32 of 43
Ok so how far because where the tv is the main phone socket is there and bt only send a small DSL cable
thomasmulhall
Message 33 of 43
I am not sure if it is a plasma because it is one of the old fat tv but from 2007
bartman1967
Message 34 of 43
Nail it to a tree a mile away from any form electrical devices like radios,microwaves or plasma TV's and use a tin foil hat Smiley Very Happy, you do know that most modern technology (from the year 1995+) have electrical shielding on, and even more modern technology have to conform to specific build qualities set out by EU regulations to prohibit interference from electrical devices, basically today's stuff will not make a blind bit of difference on your connection, if any thing goes wrong, its a malfunction somewhere between your stuff and theirs.
What's slow about FTTC........DLM 😞
thomasmulhall
Message 35 of 43
ok but i have found trying different channels help but it only last an hour then it gets slower even moving it on to the window doesent help but 5ghz is faster and is faster then using ethernet
thomasmulhall
Message 36 of 43
But why do I get full speeds on one of my old broken laptop.
thomasmulhall
Message 37 of 43
And shoulder I be having a lower noise margin
conrad
Recognised Expert
Message 38 of 43
Ideally yes but your data rate is maxxed out anyway.
thomasmulhall
Message 39 of 43
Hi but how comes I get 70 Mbps and 13 Mbps on upload on my old acer 5542 laptop but not on my new lenovo g580 laptop I only get 45 Mbps on there so I think it is not interference any more.
Deathtrap3000
Recognised Expert
Message 40 of 43
Probably an issue with your laptop. Drivers likely, but could be an antivirus or firewall issue.
