Carelessness001
Message 21 of 41
Re: Bt infinity 2 up/download not reaching guaranteed speeds
Thank you for the advise.
Looks like I shall be unable to do any remote working from home, or sending Emails from my work email client then. Thanks for the informatioin. Although Bt were made aware of the large file transfering during conversations, again records kept.
ray_dorset
Distinguished Guru
Message 22 of 41
They have been known to agree to certain business usage in the past, so as long as they have you'll be fine.
If not, I'll try again 🙂
Carelessness001
Message 23 of 41
Thank you Ray.
You have all been very helpful with your posts and I appreciate your time taken to reply. Taken from the thread, there is no need to take any further action with BT due to guanteed speeds agreed and speeds obtained. And there is nothing I can do at my end to help.
Thank you
ray_dorset
Distinguished Guru
Message 24 of 41
Like I said, you could try replacing the Homehub with a 3rd party modem/router
gg30340
Message 25 of 41
I think that things are going round in circles here and not addressing your question.
It would appear that you are getting the best speed that your line can support. Because you are within the estimated speeds it is unlikely that BT will do anything to better your speeds and in particular by approx 5Mbps.
BT do not guarantee fixed speeds. They only give estimated speeds between the ranges on the estimate checker. If you were given a verbal guarantee from a member of BT staff and can prove that you were given that guarantee you may have grounds to be released from your contract without penalty.
The only way you will be able to ascertain this is by making a formal complaint to BT and await their response.
Carelessness001
Message 26 of 41
I will look into the router Ray, thanks.
ray_dorset
Distinguished Guru
Message 27 of 41
You may even find a high speed dsl cable from ADSLnation will help
Carelessness001
Message 28 of 41
Thanks GG and again, Ray. And lic for your very informative replys
mykspence
Message 29 of 41
Carelessness001
Message 30 of 41
That is very interesting.
Thank you
