TrickyB
Message 1 of 35
Bt infinity Dropping from 74mb to 4mb in peak hours (6pm onwards)
i was one of the first customers in my street to get infinity.
Gradually its got worse and worse at night times going as low as 4mb-6mb
i have 5 wifi users with ipads etc  and sharing 4mb is no good
my mobile phone gets a better download speed than my infinity at night(14mb)
i have been on the online chat for an hour twice
changed my home hub 5 for a new one to no difference
have done all the usual tests rebooted etc one wired connection while testing
called and spoke to someone for 40 mins earlier
none of these people are able to help and are more than likely on another continent
aside from raising a complaint what else can i do?
its clearly congestion at the cabinet at peak times
anyone else experiencing this?
its fine daytime(74/19) but once 6-7pm hits its 5% of the download speed its supposed to be
34 REPLIES 34
imjolly
Message 2 of 35
Re: Bt infinity Dropping from 74mb to 4mb in peak hours (6pm onwards)
check you exchnage for problems  http://usertools.plus.net/exchanges/mso.php
http://usertools.plus.net/exchanges/?
http://btbusiness.custhelp.com/app/service_status
http://bt.custhelp.com/app/answers/detail/a_id/15036
http://community.plus.net/exchange-information/
TrickyB
Message 3 of 35
Thanks for the links
My exchange isnt showing any problems at all at the moment
Line test comes back fine
imjolly
Message 4 of 35
go to troubleshooting then helpdesk and post 1-12
run bt speedtester and when first test completes then run diagnostic test and post results
btspeedtester
enter your phone number and post results  remember to delete number  https://www.btwholesale.com/includes/adsl/main.html
TrickyB
Message 5 of 35
Cant seem to find the troubleshooting/help desk forums page you mention where should i be looking?
i did the tests which are fine till around 6 pm
Download speed achieved during the test was - 74.97 Mbps
For your connection, the acceptable range of speeds is 40 Mbps-77.35 Mbps .
Additional Information:
IP Profile for your line is - 77.35 Mbps
Upload speed achieved during the test was - 16.43Mbps
Upstream Rate IP profile on your line is - 20 Mbps
Telephone Number ************ on Exchange GLENROTHES SOUTH is served by Cabinet 22
FTTC Range A (Clean)80742020--Available
FTTC Range B (Impacted)8061.92012.2--Available
WBC ADSL 2+Up to 3--2.5 to 6.5Available
WBC ADSL 2+ Annex MUp to 3Up to 0.52.5 to 6.5Available
ADSL MaxUp to 3--2 to 5.5Available
WBC Fixed Rate1----Available
Other Offerings
Fibre Multicast------Available
Copper Multicast------Available
Even impacted speed says 61mb
i would be happy with 40mb
4mb is no good
i will run the test again later when its affected
cheers
imjolly
Message 6 of 35
which hub are you using hh5 or hh4 + modem?  only get stats from hh5
TrickyB
Message 7 of 35
1. Product name:BT Home Hub
2. Serial number:+076272+NQ51430988
3. Firmware version:Software version 4.7.5.1.83.8.204 (Type A) Last updated Unknown
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 00:01:05
6. Data rate:19998 / 79906
7. Maximum data rate:27736 / 87947
8. Noise margin:6.9 / 8.3
9. Line attenuation:11.6 / 10.9
10. Signal attenuation:11.8 / 10.9
11. Data sent/received:9.3 MB / 4.3 GB
12. Broadband username:bthomehub@btbroadband.com
imjolly
Message 8 of 35
You have max connection speed for infinity 2
Can you run btspeedtester diagnostic test again with wired connection and post results - now peak time
TrickyB
Message 9 of 35
Download speedachieved during the test was - 3.88 Mbps
 For your connection, the acceptable range of speedsis 40 Mbps-77.35 Mbps .
Upload speed achieved during the test was - 2.64Mbps
TrickyB
Message 10 of 35
That was test 3 btw with the correct speedtest username used ^
Your service was found to be performing poorly.
Please raise a fault with your service provider, stating that the BT Performance Tester tool indicates poor service throughput performance after the third test.
Something isnt right
ive been working with computers for 20 years and tried everything that i can my end
it was fine when i first got it and as more people in the street took it up its gradually got worse
my kids cant even watch things on there ipads etc at peak times when we use it most
