gaz0r
Message 1 of 10
Bt infinity disconnected and now won't re connect
Hi there,
I was on the internet and it was going really slow and then it just disconnected and now it will not reconnect, I have infinity2 with bt home hub 5 and its just staying a constant orange light on the router
I have logged it with BT but just wondering if anyone has noticed anything like this before ?
9 REPLIES 9
Message 2 of 10
Re: Bt infinity disconnected and now won't re connect
Have you checked the BT Network status to see if there is a fault in your area?
http://btbusiness.custhelp.com/app/service_status/?s_cid=btb_FURL_servicestatus
gaz0r
Message 3 of 10
Yeah I have checked and there is no reported faults
Message 4 of 10
Try ONE factory reset of the homehub by pressing a pin into the recess button on the rear for about 20 seconds. If that doesn't work you will need to wait for BT to contact you.
Helios
Message 5 of 10
If you have a constant orange light then you have no PPPoE session. You will need a BB Boost Engineer.....
It will either be a problem with your HH5 or with your profile at BT Wholesales side or a faulty DSL port in the RDSLAM......
gaz0r
Message 6 of 10
I will try a hard reset when I got home.
I recon it will have to be an engineer job to get it sorted! I have a call back tomorrow to go through some steps
gaz0r
Message 7 of 10
I done a hard reset and it connected again 🙂
thanks for your help
walkerx
Recognised Expert
Message 8 of 10
mine went down earlier but back up not sure for how long as BT have reported an issue in our area tonight
walkerx
Recognised Expert
Message 9 of 10
Well looks like ours is down again, tried logging with BT as says this has been fixed only for some patronising consultant to say 'promise it will be back on by midnight'. How do they know and why make false promises
Message 10 of 10
I suppose you'll know in 35 minutes if it was a false promise or not!
