Newbie
Message 1 of 10
Bt infinity home hub flashing orange
Last night we had a power cut and since then my power light on the hub is just flashing orange, I've tried turning it on and off, pressing restart and turning on and off atplug yet it just flashes orange. Any ideas?
9 REPLIES 9
Expert
Message 2 of 10
Re: Bt infinity home hub flashing orange
Are the lights synching on the openreach box (white one)?. If they are you should synch on the HH3, if not there is an issue with your line. Is anything unplugged or wire come lose on the master socket?. Have a good check at all the equipment.
Please click on white star to the left and say thanks if I have helped you at all!. 🙂 Thank you. Some handy links Copy & Paste:-
http://bthomehub.home/
http://netalyzr.icsi.berkeley.edu/index.html
http://diagnostics.bt.com/login/?workflow=Speed
Newbie
Message 3 of 10
Yeah all the equipment is fine and the modem is working ok all the lights solid green etc, just the hub, I've tried power cycle afactories to factory reset but thgo orange flashing power light just keeps flashing the only way it stops is if I turn it off.
Expert
Message 4 of 10
Seems a bit weird that one. Maybe your HH3 is not working, I mean broken some how.
Newbie
Message 5 of 10
Thanks for your help anyways, I'll give 'em a call now.
Expert
Message 6 of 10
thanks, its ok anytime!. 😉
Distinguished Guru
Message 7 of 10
But, what happens if you unplug ALL the connections going to the hub, bar the power lead, then disconnect any devices connected by wifi, then press and hold the red recessed button for 15 seconds until the flashing light goes out and then release the button?
If it continues to flash, then this does confirm it's broken
-+-No longer a forum member-+-
Guru
Message 8 of 10
Believe that is an authentication problem which more than likely need an engineer visit as it can be a bad ciricuit.
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
Message 9 of 10
If it is the power light that is flashing orange it is a faulty hub not an authentication problem there are many references to the problem if you use the forum search feature
Recognised Expert
Message 10 of 10
Sounds like the powercut caused a power surge and has damaged the hub Smiley Sad
