Clayton_ni
Message 1 of 9
Bt infinity speed drop
Hi My speeds are fine all day getting what I'm ment to be getting but during the evening they drop way below guaranteed speeds. Been on the phone to bt call centre india two or three times but there no help can anybody help m thanks
8 REPLIES 8
imjolly
Message 2 of 9
Re: Bt infinity speed drop
post the stats from your hub and also run btspeedtester and when first test completes then run diagnostic test and post results  do this when speed is good and in evening when there are problems
which exchange and cab are you on
Clayton_ni
Message 3 of 9
Hi. I'm new to this how or where do I go to post that stuff I just normally use speed test and my speed normally runs steady 50 to 60 meg but evenings can drop to as low as 5 meg for a few hours. My exchange is in armoy northern Ireland. Thanks for your help
imjolly
Message 4 of 9
run the test here using a wired connection  when first test completes then run diagnostic test and post results  http://speedtest.btwholesale.com/
Clayton_ni
Message 5 of 9
Hi. I have no way of running it wired unless it works on xbox one I'm afraid
imjolly
Message 6 of 9
only the reults of a wired connection are acceptable to show low download speed as wireless are affected by your home conditions and no ISP guarantees speed on wifi
Clayton_ni
Message 7 of 9
Ok understand that I'll get them posted soon as. It's just it happens every evening and it's really annoying my wifi speeds are always consistently good right beside hub. Until the evening and it slows down really bad. Is there anyway of letting bt know without having to go through an Indian call centre. And thanks for all your help
imjolly
Message 8 of 9
the forum mods will be able to help/check your exchange but need btspeedtster wired diagnostic results showing speed when good and then again when bad
Clayton_ni
Message 9 of 9
No sweat I'll get them posted soon as I can thanks for your help
