Shoxen
Message 11 of 15
Re: Bt infinity
My address doesn't but all my neighbours do
Webby
Message 12 of 15
Re: Bt infinity
It's possible there's no room left in the FTTP equipment or simply a records issue.
I suggest contacting Openreach via the webform on their website.
Shoxen
Message 13 of 15
Re: Bt infinity
I'll give it a go. They sent me a ref number but that's all.
herrbohnen
Message 14 of 15
Re: Bt infinity
i wouldn't get your hopes up , my infinity is worse than my old copper one, one minute it's 50 Mb , the next 0.005
Shoxen
Message 15 of 15
Re: Bt infinity
Has to better than 2Mbps.
