Shoxen
Message 1 of 15
Bt infinity
Hello. So I have done some research and discovered that the exchange I use is fibre enabled bit minevitable is 9n e9 for the few houses that doesn't have infinity. How can I get this resolved.
The exchange is nanpean cabinet 3.
Tags (1)
14 REPLIES 14
Webby
Message 2 of 15
Re: Bt infinity
Can you run this checker for your line http://www.dslchecker.bt.com and post the results.
Shoxen
Message 3 of 15
Re: Bt infinity
http://www.dslchecker.bt.com/adsl/adslchecker.TelephoneNumberOutput. hope this works. If I do the check for my neighbours opposite they get fttp results too.
Shoxen
Message 4 of 15
Re: Bt infinity
Sorry I that hasn't worked. How do I post results?
pippincp
Message 5 of 15
Re: Bt infinity
Copy and paste.
Webby
Message 6 of 15
Re: Bt infinity
You can screenshot it and upload an image. Or copy and paste the data
Webby
Message 7 of 15
Re: Bt infinity
From what I can see, postcodes on your cabinet should have FTTP. Note that the cabinet is irrelevant for FTTP however that's how the data is displayed on codelook.
Shoxen
Message 8 of 15
Re: Bt infinity
ADSL Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
Left in Jumper
WBC Fixed Rate 1 -- -- Available -- --
Other Offerings
Availability Date
ADSL Multicast -- -- -- Available -- --
Shoxen
Message 9 of 15
Re: Bt infinity
I get better results from the address itself. From what I can see the people directly opposite us get fibre. Just wanna get fibre sorted as I have a growing family to try and keep entertained.
Webby
Message 10 of 15
Re: Bt infinity
Does the address show FTTP available? But the phone number doesn't?
