Message 1 of 6
Bt internet cutting out?
In  Northern Ireland, internets cutting out. This is happening every 20 minutes now. I can't even post this. It cuts out for 2 minutes, comes back, cuts out again.
5 REPLIES 5
Message 2 of 6
Re: Bt internet cutting out?
@ScrewBeeTea
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
Message 3 of 6
What does this have to do with the issue
Message 4 of 6
The broadband comes down the phone line. If the phone line is noisy or disconnected, the broadband will disconnect.
Message 5 of 6
It's a diagnostic step to check if there's an issue with the phone line. Have you spoken to BT about the issue as well?
Message 6 of 6
https://speedtest.btwholesale.com/
run standard test then run additional diagnostic
It found a error on my line about a year ago i didn't even realise was there as we rarely use our house phone
