thomasmulhall
Message 1 of 3
Bt smart hub keeps restarting its self
Hi when I did the first restart the Bt smart hub now just keeps restarting its self every 3 mins.
It takes like an 1hour for it to connect to the internet then it keeps restarting so I carnt use the wifi.
Does this mean it is faulty
Should I get it replaced.
2 REPLIES 2
Keith_Beddoe
Message 2 of 3
Re: Bt smart hub keeps restarting its self
Disconnect all of your wired and wireless devices, and see if the hub keeps restarting. If it does, then its faulty.
If it does not, then its one of your devices that is causing the restart.
thomasmulhall
Message 3 of 3
Hi, we called bt and they are replacing the router. We are using an apple airport express temporarily and everything is connecting to that fine. No reboots yet.
