D------t
Message 1 of 4
BtInternet toolbar
Hi does anyone know if this is a genuine btinternet toolbar ? http://btinternet.ourtoolbar.com/   Smiley Mad
or if this one is genuine, http://assets.bt.com/v1/btcomd/toolbar/index.html
thanks in advance
3 REPLIES 3
Message 2 of 4
Re: BtInternet toolbar
The first one is classed as Adware, by OpenDNS, the second one is not. Based on that, I would not use the first one.
Its also not part of the BT domain.
Toolbars in general, offer little benefit to the user, and are mostly used to trac web users activity, so are best avoided.
duncan10
Expert
Message 3 of 4
As regards toolbars-DONT download the yahoo tool bar  or you will spend hours regretting it . And watch you dont download it as part of a programme you are downloading. ALWAYS go for the custom install
Distinguished Guru
Distinguished Guru
Message 4 of 4
Agree. There's little or nothing on extra toolbars that you need and often plenty that you don't want. Always be careful not to leave boxes pre-checked when downloading, even if you trust the site.
